HELLO TO ALL,
I just signed up to be a member an I'm hoping for some good advice. I have the opportunity to buy a 97 GMC Suburban at a good price, however it will only move in reverse.
Truck is mint. 131K, engine is strong, interior & seats great, tires good, fluids look pretty clean but it has been sitting for about a year. Once I've started it up I can go in reverse with no problem, go to N, non problem, go to D I can hear a little bit of noise hard to discern what it sounds like, but when I cycle all the way from D to 3 no noises, same as I come back except a bit of noise going back through D into Reverse. I've put it into 4x4 both HI & LOW and repeat the steps above and still the same outcome.
From what I've read, it appears the transmission is shot. BUT, if someone can provide me with a different solution to fixing this problem please post back. I[m hoping for a small miracle.... ..
If in the end it's proven to be a bad tranny, what is the price of buying a rebuilt one? Or should I try to part out the truck? Or should I walk away from it. Any guidance will be greatly appreciated.
thanks,
ketelone
thanks,
ketelone
