'98 gmc Yukon rear door speakers won't make any noise at all. Broken or simply
Mike
not installed? If not installed, how can I hook them up? thanks
If not installed, how can I do this? Car has aftermarket Sony head unit also (if that matters)
Actually, the Sony head unit makes all the difference. The rear door speakers in your Yukon are run by a factory amplifier. To make the amp work, you need to connect the amp activation wire in the factory radio plug to the blue/white remote output from the Sony head unit.
The amp activation wire should be pink. If you're using an adapter harness to connect the new head unit, the pink wire should connect to a blue wire in the harness.
