Jerry Welch
- Oct 12, 2013
When the engine is cold or the outside temp is below 65 the engine will not fire. A squirt of starting fluid or gas in the throttle body allows start. Engine runs well on the road. Idle is quite and smooth. Replaced the fuel pressure valve. Fuel pump is a year old. Is some sensor causing the problem?
