Here is where my issue begins I posted this on another forum with no results.
Hi All:
New guy with Envoy. Have only had it for a month or so now. I think there may be an issue with the air suspension. I loaded about 100lbs of equipment in the back and when I came out the next morning it was riding low (i think all the way down). I didn't think anything of it as it rose up when I started the truck.
On the other hand I had the same equipment in there a few days later and had slammed on the brakes to avoid hitting a deer on the highway and noticed that the back end had dropped. It was riding low and all the way down. I had to turn on the ignition about 2-3 times and move the truck a bit for the bags to inflate and the truck to return to normal height.
AND the next day I was driving and had to hit the brakes hard (although not as hard as avoiding the deer) and the back end again dropped down all the way which caused me to pull over at a gas station and turn off and on the engine 2 times and move the vehicle for the bags to return to normal.
one more... I loaded about another 100lbs (200 +/- now) and parked on a slight angle on the grass and noticed the back end had dropped down again. I started the engine and drove it around the driveway and it returned to normal.
I can't figure if this would be cause by a sensor, bag deterioration or something else. When I start the engine the compressor does come on but doesn't inflate all the way (only stays on for a minute or less) which is why I start it a couple times and drive it a short distance.
Anyone have any ideas? What would happen if I drove it with no air for any amount of time? I am trying to determine if this is something the dealership should repair under the lemon law warranty and want to do some research before I bring it to them as a concern.
I did pull the fuse for a bit to see if would reset something. It has not done it since (that I noticed anyway) I am back to the 1st 100lbs of equipment in the back.
Thanks In advance!!
Hi All:
Thanks In advance!!
