Ball joint inspection time, be safe friends
Molson02536
K/W Ontario Canada
Second gen blazers the checking procedure is as follows:
UPPER BALL JOINT CHECKING
1. Raise and support vehicle with jack stand under lower control arm, near lower ball joint. Ensure upper control arm bumper does not contact frame. Place dial indicator against lower part of wheel rim. Push in on bottom of tire while pulling outward at top. Read dial indicator, then reverse push/pull procedure.
2. If lateral (horizontal) deflection exceeds .125 (3.18 mm), replace ball joint. With ball joint disconnected from steering knuckle, try to rotate ball joint by finger pressure. If ball joint can be rotated by finger pressure , replace ball joint.
LOWER BALL JOINT CHECKING
Raise and support vehicle with jack stand under lower control arm, near lower ball joint. Place dial indicator on spindle hub. Pry wheel between lower control arm and outer race to measure vertical movement. Note: dial indicator reading. If reading exceeds .125 (3.18 mm), replace loose ball joint.
Don't for get to also check your steering linkage also for excessive play also, be safe and enjoy another season of winter fun around the corner.:eek:
