big problem!!!
Mrlaziman
Age
33
brooklyn newyork
:eek: my dad has a 04 gmc savana 3500 cargo van i use it to go to school sometimes for a while now the blinkers have been blinking fast when the van is cold and the back up lights dont work at all IT SA NOT ANY OF THE FUSES so i decided to try and c wut the problem is so i found the relay and i looked inside of it then put it back together and pluged it back in and now the l&r turn signals aren't working nether is the check engine light that waz on only the hazards did i damedge something pleeeeeeeeez haep heez gonna kick my ass i think
Replace your turn signal relay and inspect all your turning lights. A bad turn light will cause your flashers to flash fast. As for your back up light, you sure the bulbs are not just burnt out???
keep us posted to let us know your still alive :D
when 1 of the turn signal bulbs are bad it doesn't blink it just stays on the backup bulbs are brand new how do i noe if the flasher relay fuse is bad?
Flasher is bad, if the turn signal lights don't flash. If the lights flash fast, then it's one of the bulbs. Back up light's are the right ones??? that was installed. At worst, its going to be a bad connection at the back up light switch. :eek:
i got the flasher unit .... i know i took a long tine but anyway my blinkers still doesn't work only the hazards ?
