I have a 95 jimmy 4wd 4.3 vortec, when you start the car cold and drive it down the road it will blow a lot of smoke looks bluish gray. It will miss when you first start it cold. In a matter of a minute the miss will go away truck runs fine. You can drive truck and as it gets to normal temp range the smokeing will quit, You can park truck let it sit 10-15 mins start it and it will have miss again which goes away,Drive truck no blue gray smoke.Let sit 9 hours start it it will miss and blow blue gray smoke until warm again.I see no indication of water in oil, I'm thinking that intake gasket is bad and as truck warms up everything expands and seals up spot in gasket? Any ideas anyone? Any info would be greatly appreciated.
