J Joey New member Joined Aug 21, 2010 Messages 6 Reaction score 0 Points 0 Dec 23, 2010 #1 With lights off, brake lights work dimly. When you turn the lights on, the brake lights do not work. Turn signals flash fast. New circuit board, light switch, & bulbs. What the f**k could be causing this???
D drew92472 New member Joined Dec 23, 2010 Messages 1 Reaction score 0 Points 0 Dec 23, 2010 #2 If the turn signal lights on dash light up with brake lights then it is a bad ground,,, if not check for a corroded wire under back of truck,,
