CD disc stuck and will not eject from 2004 GMC Envoy?
Paul M
I have a CD in my 2004 GMC Envoy that will not eject. When I push the eject button, I hear clicks, but nothing happens. There doesn't appear to be a little hole for me to use a paper clip (like I see on my computer). Any thoughts?
go to ur closest audio shop and they can take a look at it usually for free
Someone is going to have to take the deck out and get the disc out through the back.
There is a GM bulletin out about this concern. I'll post it for you to read, but it basically says to pull the radio fuse from the under hood fuse block, leave it out for a minute and then reinstall it. Try to load a cd or press the eject button to make sure that one is not in it. If you can then load a cd then you will need to have it reprogramed in order to keep it from happening again. If this does not work, then the radio will need to be replaced. Here's the bulletin:
#04-08-44-020C: CD Player Long Load-to-Play Time, Error Message, CD Does Not Return to Previous Track, CD Does Not Play, CD Does Not Eject, CD Stuck in Player, Radio Will Not Accept CD (Reprogram Radio) - (Nov 9, 2005)
Subject: CD Player Long Load-to-Play Time, Error Message, CD Does Not Return to Previous Track, CD Does Not Play, CD Does Not Eject, CD Stuck in Player, Radio Will Not Accept CD (Reprogram Radio)
Models: 2004-2005 Buick Rainier
2004-2005 Cadillac Escalade, Escalade ESV, Escalade EXT
2004-2005 Chevrolet Avalanche, Express, Silverado, Suburban, Tahoe, TrailBlazer, TrailBlazer EXT
2004-2005 GMC Envoy, Envoy XL, Envoy XUV, Savana, Sierra, Sierra Denali, Yukon, Yukon Denali, Yukon XL, Yukon XL Denali
2004-2005 HUMMER H2
with CD Player Radio (RPOs UB0 or UB1)
This bulletin is being revised to add 2004 model year. Also, additional conditions and correction information have been provided. Please discard Advance SI Resolution Bulletin Number 04-08-44-020B (Section 08 - Body and Accessories).
Condition
Some customers may comment on one of the following conditions:
• Long CD load-to-play time
• CD ejects with an error message of "CHECK CD"
• CD does not return to previous track after an ignition cycle
• Clock resets to 12:00
• CD does not play
• CD does not eject
• CD stuck in CD player
• Radio will not accept CD
Cause
A software anomaly within the radio has been found.
Correction
If the customer comments that the CD does not eject or the CD is stuck in the CD player, or the radio will not accept the CD, prior to programming the radio, perform the following steps.
Turn off the ignition.
Remove the radio fuse for a minimum of 30 seconds.
Reinstall the fuse, turn on the ignition and the radio.
Attempt to remove the CD by using the eject button or attempt to insert the CD.
If the CD was successfully removed or the radio accepted the CD, then proceed with reprogramming.
If the CD was not successfully removed or the radio did not accept the CD, then the radio must be removed for repair at an authorized Electronic Service Center.
Reprogram the radio with an updated software calibration. This new service calibration was released with TIS satellite data update version 10.0 available October 3, 2005. As always, make sure your Tech 2® is updated with the latest software version. Prior to entering TIS2000, enter the VIN into GM VIS to obtain the RPO codes of the radio and speaker configuration for the vehicle. This will allow for the correct calibration selection. Selecting the incorrect calibration for the vehicle configuration can damage the radio and lead to unnecessary delays in repair time. Once programming is completed, wait at least one minute after key-off to allow the radio to accept the new calibration.
Important: TIS programming supports two calibrations for radios with the UQA amplifier on the S/T models. Prior to selecting the calibration, determine if the amplifier is class 2 or non-class 2. Use the Tech 2® and the following path.
Connect the Tech 2® to the vehicle and power on.
Select "Diagnostics" from the menu.
Build the vehicle from the menu options.
Select "Diagnostic Circuit Check" from the menu.
Select "Class 2 Message Monitor" from the menu.
If the amplifier appears on the class 2 message monitor screen, then the calibration for a class 2 amplifier needs to be selected. If the amplifier does not appear on the screen, then the calibration for a non-class 2 amplifier needs to be selected. Selecting the wrong calibration will result in reduced or no radio volume.
Also, please advise the customer that home-burned CDs must be burned with a "closed session" or the formatting will be incomplete and the player will not read the CD. CDs should NOT have adhesive paper labels affixed to them as the labels may lift off in the player.
Most of the time when this happens, it's because the radio doesn't realize that a cd is in it. When you remove the fuse it resets it and sometime will let you eject it. If it makes a clicking sound when you hit the eject or when you try to put in a cd, you will need to replace it, or have it sent to technicar to have it repaired.
The fuse is located in the underhood fuse panel. It is the one listed as RADIO. Technicar is the company that repairs these for GM. I'm not sure if you could contact them directly to have this repaired. Typically, they just give you a new one, well they call it new but it is actually one that they have rebuilt. They take yours on exchange and will rebuild it and resell it.
Try this, turn your ignition on to the accessory position. Hold the eject button down for 2 or 3 minutes. Depending on your make/model, the eject button may flash. When the button stops flashing (or when a few minutes has passed), release the button and immediately press it again (theory being that the two minutes of "work" followed by a quick break will fool the player into releasing the disc when you press the eject button again). :eek:
http://www.oemautosound.com/c-151-gmc-products.aspx
CD disc stuck, help finding the fuse
Greetings,
I am very exicted to see this post, as we have the same issue with our 2004 GMC Envoy - however, my father and I are having trouble finding the fuse referred to in the previous post. Do you have any pointers? I am also looking online for something better than the owners manual. We are hoping to fix this ourselves - the dealer said they'd have to take the entire dash panel off to access the radio and fix the issue.
Hi you should find the fuse your looking for under the rear seat behind the driver... it is under a black cover like the one under the hood...
sad to say this did not fix the CD issue for me anyway:(
