No, it will be a direct bolt-on swap. Nothing special is needed.
The only major differences would be if one truck had sealed-beam headlights (glass type), and the other had the composite (separate low and high beam bulbs in a plastic housing). Then you would need new headlight buckets.
If both have the composite headlights, then the headlight and turn signal housing are identical. Nothing else is needed, but the inner and outer grilles.
