Cylinder head ID '01 C3 6.0L
Animalmutha
Like the title says what castings did the '01 come with? Were they all the same through out the model year? Thanks
There two casting numbers for the years 01-04 for the 6.0 ls engines. One is the 317 and the other is 035. One was used for the higher compression ratio set up with a flat top piston and the other with a lower compression with the use of the dome piston.
Your going to have to find out if your have a LM7 or LQ9 engine to determine which heads you have.
Hope this helps
Molson02536
