Drivers side turn signal and brake disappeared
Orr84
Hi everyone,
This is a 2010 Sierra 1500… I am having a hell of a time figuring out what’s created this issue. Discovered my reverse bulbs weren’t functioning (and not enjoying everything tinted out in my rear windshield/Cap etc… thought I’d get some LED’s To brighten up night time reverse). Checked the fuses, everything was fine pre-install. Put in the LED reverse lights, everything was working and it developed a hyper-flash when I went to turn left… turns out I also don’t have a drivers side brake light either…
So, I took out the LED lights, put all stock bulbs in… and nada. Here’s a quick video
A different forum mentioned a J-case Fuse was the culprit of a similar problem but I don’t know what J case fuse would be linked to the drivers side.
Everything worked previous to the LED’s and now I seem to have lost my entire drivers side function With regards to brake light, turn signal and hazards. Running lights, reverse lights, taillights, headlights, fog lights, high/low beams function as they should.
