Electrical Issues:
1. Center High Mounted or third brake light is not working. The two bulbs were burnt so I replaced it but still not working.
2. Tail light on driver side is not working. The brake, turn signal, hazard are working. This is on the same bulb. The license plate light is also not working so I think its on the same circuit.
Done so far: I replaced the Headlamp switch. Loosen, clean and re-tightened negative battery cable at engine side. Also disconnected, cleaned body ground connection at the tail section. It didn't fix the issue.
I am hoping someone had this issues and kindly post the fix. Thanks in advance for your time.
