Hi all,
I recently did a scan specifically for ABS System on my 96 Jimmy SLS 4x4, and it came up with the following codes:
B1268 - Pump Motor Shorted
B1251 Rear Isolation Solenoid Circuit Open
B1245 Left Front Isolation Solenoid Circuit Open
B1241 Right Front Isolation Solenoid Circuit Open
B1221 Right Front Speed Sensor Circuit Open
Now what is interesting is that after each one it says HISTORY. I have no idea what that means. Also I should mention that my ABS light is NOT ON. It lights up when I start my truck then goes off just as it is supposed to according the manual. My understanding is that if there is a problem with ABS then the ABS light would stay lit indicating an issue, but that is not happening. I will also mention that I have triggered the ABS to kick in by hitting the brakes hard on a wet bumpy surface and they did engage. So at this point I am really confused on whether or not I have a problem.
I also have two other OBD codes:
P0442 Evaporative Emission System Leak Detected (small leak)
P0753 Shift Solenoid A Electrical
The Evap one I have been hunting down for a while with no success. The Shift Solenoid one confuses me as I have no trouble with my transmission (other than the leak that I need to take into the shop to get addressed). But as far as shifting goes everything works fine. I have 1-4 and OD just as I am supposed to. Shifting from 1st to 2nd is a harder shift than all others but it's not super hard or jerky, just different than the rest.
I know this is a lot, but I am at a loss. Thanks.
