First oil change?
90C4
2011 1500,5.3 would like to go to synthetic,oil moniter says I'm at 50%.Do not want to change to early,any imput?
First I would not change to the a synthetic oil till about 35,000 give the motor,piston & rings time to seat ( break in ) work all moving parts to a very smooth mating surface. That's my opinion as far as the 50% info its telling you that 1/2 of the life of the oil is used or left so don't change till it says 2 or 1 % left. Then at that point the oil life is used up and I set the trip also so I know that it really should be changed at 5 or 6 thousand miles instead. Of a computer telling me when it thinks I should changed it that's my take on it also if you have a aluminum engine block you don't have to over tighten the oil plug make it snug if it doesent leak ur good if it does than cinch it up a bit nothing than stripping. The oil plug......
The oil life monitor (OLM)does not actually measure the quality of the oil. It provides a gross estimate of oil life based on a computer algorithm developed using a specific type of oil.
You don't have to wait to change to synthetic, change anytime you want. Remember the oil they put in at the factory was supplied by the low bidder. I put synthetic oil in my vehicles at about 1,000 miles. My Cadillac CTS cames with synthetic oil.
The idea that engines need to break in before using synthetic oil is a myth. It was common years ago for engine manufacturers to recommend non-detergent oils for engine break-in. This was when the pistons used cast-iron “square-faced” rings and the rings needed to wear some to “seat” into the engine. With today’s technology of oils and engine manufacturing, engine manufacturers no longer recommend the use of non-detergent oils for the break-in period. In fact, many engines today are factory-filled with high quality synthetic motor oil, Corvette, Cadillac for instance.
Benefits of Synthetic Oils
• Improved low temperature characteristics for faster starting and quicker flow to critical parts
• Improved stability through a wide range of temperatures
• Improved fuel economy (.4-.6 MPG) due to reduced internal engine friction and windage (the drag produced by parts moving through the oil bath)
• Emerging and future vehicle emissions regulatory requirements partly depend on the advantages of these high technology lubricants to achieve certification standards.
• Reduced engine deposits
Every lubricant in my truck and car are 100% synthetic. I use nothing but AMSOIL since 1975.
2010 GMC Sierra ECSB SLT Z71 All Terrain
2009 Cadillac CTS4 AWD Performance Sedan
