i have a 92 gmc sonoma with 4.3 v6 throttle body fuel injection. it's an old beater but it runs relatively well most of the time, until recently. about 3 years ago she quit on me and i replaced the fuel pump. problem fixed. about 2 years ago it quit like before. i replaced the fuel pump again only this turned out not to be the problem. once i got it to a mechanic, i was told that a fuel injector had gone bad. 300 bucks later everything seemed to be fine, until last summer, a real hot one here, it wants to buck and sputter after it's run for awhile. i have good fuel pressure, new fuel filter, tuned it up with plugs, wires, cap, and rotor. this was last fall right before i took a long trip with it and it seemed to subside, but the heat wave had subsided so i may not have got a good feedback. anyway, ran alright since, until now and the high heat is back and it's started bucking again. it seems to run fine at high speed but when you drop back to about 30mph, or let it sit a bit and crank it up to go again, it gives you that act like it's out of gas, or not getting any.
can anyone point me in the right direction on what to look for or replace?
