Hey folks,
I drive a 2000 Sonoma 4.3L automatic transmission. On the way home last week the engine sputtered and stalled. After pulling off the road, I was able to restart but the accelerator was unresponsive. The engine was starving for fuel. After I had the truck towed home I noticed that the fuel pump was not running. I changed out the relay and no joy. Next I installed a new fuel pump and sending unit. Now the fuel pump still doesn't work and the fuel gauge does not work either. I checked for voltage at the pump across the gray and the solid black wire and there are only a few mili volts. Voltage across the sender is 5 volts as it should be but the gauge still does not work.
Should I be looking somewhere else for pump voltage?
By the way, I bought this truck brand new and have not had any engine problems. I did replace the ECM a year ago for a transmission issue but not problems since, until now. Any help is greatly appreciated.
