Longhorn1972
2003 GMC Sierra 2500HD
Just replaced the fuel pump through a mechanic. Noticed that the fuel pump module seems to run constantly. Wondering if I should be concerned that it will burn out or is this normal?
I should note that this is happening while the truck is running. Not just when you turn the ignition forward but do not start...
Delphi Fuel Pump
ACTUAL OE PART - GAS ENG - w/o EVAP EMISSIONS SENSOR STAMPED TCU
Thanks for your help!
Delphi Fuel Pump
