barks507
Can someone give me an idea of how many kilometers I should be getting from a full tank. I drive it pretty easy.
4.3L Auto 4x4 SLE .Regular fuel.
I get about 180km on 20 liters on my jimmy from Cambridge,On to Toronto,On round trip constant, but i have mod out my Jimmy so you should be around the same area and i have to run the 92 octane min or i have problems. Changed rocker ratio, removed the throttle blade restriction plate, removed the particle screen on the MAF sensor, K&N filter, high flow cat, 2.5" cat back single exhaust and Dyno tuned to 195kph, and running 255/60-15 for tires all the way around and replace the transfer case with BW4472 AWD for a full time use wet or dry pavement.
