Fuel smell when you fill your GMC Sierra
Jimmy
I had the same problem. I could smell fuel only when I filled my tank to the top. It took me a while but I discovered the seal around the sending unit located on the top of the fuel tank of my 2010 Sierra was leaking, causing the fuel smell. I just replaced the O ring seal and retainer ring and when I filled the tank, it leaked around the seal again. Before I reinstalled the fuel pump assembly back in the tank I noticed that the plastic lip that sits on the O ring seal had several cracks in the plastic and may be the reason why the seal was no longer effective. This may be the cause of your gas smell.
