How can I get my 92 GMC Jimmy started?
Chris
Ok so i've changed the starter, fuel pump, fuel filter, Battery, Spark Plugs, and new wire set. It catches if I spay ether in to it, but as soon as it sucks up the ether, it stops. I am completely out of Ideas on where to go from here. Please help me.
needs feul.
fuel injectors.
fuel pump relay?
fuelpressure regulator?
... whne you turn the key to ON--can you hear the fuel pump? if so, dont worry about the relay.
when you try to start it, take the breather off--crank it while some one looks into the intake--you see gas? (if it's a TBI injection, which mine is) if you dont, then it's a injector problem of some sort--check the harness conenctions, go from there.
fuel pressure regulator is a huge possiblity.
good luck.
just some ideas to toss at you.
Here is a link for you to retrieve your DTC codes, you may get lucky and there may be a code that will lead you to the issues that is keeping your engine from starting. Like a bad ICM or bad crankshaft sensor and as mentioned, the fuel pump relay which is located in the firewall by the brake booster. The one on the passenger side is the fuel pump relay and the other is the A/C relay, you can switch them around. :rolleyes:
Keep us posted and be glad to help you get your Jimmy running again.
http://www.troublecodes.net/GM/
