On my '97 the top bar broke on mine and when I replaced it, there was a slight amount of elongation to the holes for adjustment up under the trim plate. Also, I am looking to replace the bushings in the hinge on my third door, but don't want to spring for the dealer fee. Parts stores don't make a repair kit for the third door that i know of. Front hinge repair kits are like $6 at most auto parts stores, you might want to try that as it won't hurt anyway. The bushings wear out where the pin goes thru. Otherwise, there is the factory fit method. i worked in pre-delivery and fit doors, hoods, etc. You can bend (gently) the striker into complience with a tool. We used a wooden mallet handle. Good luck!
