I have a 2000 GMC Savana that has a problem?
casey
I was at the gas station and after a fill up my car wouldnt turn on we pushed it out of the way later that day we hanmered the gas tank about where the fuel pump is and it started after a few pounds and few attempts to start is that a sign that is the fuel pump going out or could it be something else
If it was cold over there then thats the problem.
Maybe something was leaking out.
My car was leaking something out.
If it is leaking then go to the repair place near you.
If it is cold also go to the repair place near you.
Hope your car works
Fuel Pump...and Change That Gas Filter That's Probably Never Been Changed
Fuel pump without question, its starting to lock up just like a starter does. If its a lose connection you will see it when you pull tank down
