For some reason I have no power anywhere, Replaced the battery and all but it wont start, Won't unlock doors or roll up windows, ect. we even tried boosting it off and still nothing. Help please
The positive cable that runs to the starter is probably rotten at the end by the eyelet and you dont have proper power distribution. It is a very common problem. Be careful not to break off the starter solenoid end when removing the 13mm nut on the starter. Look under the passengers side area between trans and engine under exhaust manifold. The large wire that goes to it is the positive cable. It should have no green corrosion or be deteriorated.
