ozzman5583
- Aug 20, 2012
the engine is getting fuel and it is sparking but wont start the fuel pump gets powered on but just cranks when the keys turned and the spark plugs when i took them out were covered in gas i have changed map sensor ignition coil and sending unit the injectors have been replaced b4 i bought the truck and i replaced the idle air control valve and the ignition control module and wires and plugs but if you dry off the plugs and start it it will fire up and idle but give it gas and it stumbles and back fires through the intake and shuts off
