save your money, this stuff is all worthless crap on a stock motor. your vehicle has a cold air intake on it now, about the only thing you will succeed in doing is messing with your computer, making the fuel mileage worse, and possibly leaning out the motor, which will burn a hole in a piston. Talk to your mechanic, none of this plastic crap,or spacers or sooper dooper power scooper chips will do anything but empty your wallet. If you want an extra 100 horsepower, find a later model engine with a turbo on it, this will give you the zip, zap , zing you are looking for so you can spank your neighbors crappy hondayota,There is a lot more information coming out now about engines, and transmissions blowing up after installing power chips. GM has voided the warranty on thousands of cars that installed power chips, and other manufacturers may follow suit. I heard about the diesel engines blowing up, right from the beginning, in 92, which is about as far back as you can go to find a vehicle with a computer to program, unless an engine is built to be programmable for the most part anything you do to make an engine work harder, means it blows up that much sooner. Some chips do little more than change valve timing. You want a 350 hp motor? you have to buy one or build one, gm performance has some interesting crate motors available, as do other manufacturers like edelbrock and many others, all it takes is about 6 grand.
