MAF cleaning Q / survey
ferretx9
As this ( part ) seams to be a popular " check this 1st " reply
to almost every Q concerning an engine that's running like a 3
legged dog in a hail storm , and as I can't find where anyone has asked ,
I will , hell , I ain't shy . Timid yes , shy no . ;)
Should MAFs be cleaned on a regular basis ?
Or do you feel its best left alone till a problem occurs ?
If yes , then how many miles / time between cleanings
and what product would you recommend ?
well i would say the real question here is............. how many people that had a running problem (with out a k&n air filter) cleaned there mass air flow sensor and had it fix the problem.
I can say this in my part of the world it's about 1 in a 1000
Yeah he's right, it barely ever fixes the problem. however if you want to clean the MAF buy some electrical contact cleaner and gently spray the elements. keep your distance though, its very easy to break an element. then get a can of compressed air and gently blow off the dirt and excess cleaner, if you use an air compressor drop down your line pressure almost as low as it goes. let it dry and re-install. you may want to seperate the sensor by removing the four screws to make cleaning easier, just take your time! good luck!
I think the "clean the Maf" is pretty standard is its fairly easy to do by anybody with some small wrenching ability. I myslef am chasing a small gremlin.. my 96 runs 'almost' fine.. there is enough of a rough idle I feel its just quite not right. Gas Milage seems normal, starting is slightly sluggish.. like it cranks .5 seconds longer then it should. If it wasnt a new fule injected car I would say it starts fine.
bad runing engines can be quite a varity of things, and there is seldom a "do this" that works all the time. Cleaning the MAF is easy and eliminates a problem. But there are so many more things. Vacume leaks, I just buy a can of starting fluid and spray it around the vacume fittings, if your engine speeds up, you have vacume leak. This method also will help you narrow its location down. Thats also easy for almost anybody to do. Then you start getting into more complicated stuff. Reading codes, checking plugs and wires, fuel pressure. I read alot about the fuel pressure being issues on these trucks, Fuel pumps seem to be a common weak spot ( from forum reading) and can cuase several issues, hard start, poor idle, lack of power. Problem is a good fuel pressure tester is not cheap.. and the Fuel pump is not a cheap part either $300 from GM or if you get lucky $200 oon Ebay for a GM (delphi) part.. or if you like gambling an aftermarket for $120+...After that its sensors, low compression, computer, etc.. none are easy to track down unless you really know what you are doing.
people tell you the easy things to test first as they cost almost nothing and anybody (almost) can do them.
me im at the fuel pressure thing, i did pick up a cheap gauge at Harbour Frieght for $20 but reviews show it works about as good as it costs.. so I'm not sure if i will get an acurate reading or not.. and if i dont know, can I trust it .. if it says my fuel pressure is ok.. did I eliminate that as an issue or is the guage wrong and I just think its right ( the negatives of cheap tools).
My 05 Sierra 5.3 has been throwing maf code lately. I bought a can of maf cleaner at canadian tire on the weekend,removed the sensor and cleaned it but later that day code came back. Is it safe to say i need a new sensor?
