Hello! I have a 2000 Sierra with 250000 KM's on it. Last winter I had no oil pressure and cream color engine oil. I brought it to a shop and they ended up tearing down the engine to get to the head gasket and heads. What they found was the heads were warped. So they got them milled down flat again and put them back on. Worked great after that. Well this Winter I now have the same problem. I have babied this truck since then and I really only use it for short trips to and from work and renos at home. I have actually only put on about 1500 KMs since those last repairs. I was told that it might just be condensation from the short trips to and from work.(hot/cold/hot/cold...). I think it is something else. Bad oil pump? Short in the gauge? And yes I did check to see if there was oil in the engine. Runs at the right temp. The coolant level has not really dropped, but it is blowing a whiter exhaust out of the pipe.
I'm not really mechanically inclined but I kinda understand how an engine works. Any Ideas on what the problem could be would be greatly appreciated.
Thanks,
Eric
Thanks,
Eric
