Hi, One day while driving the sound stopped working, believing it was the radio station I tried multiple others. radio was able to switch stations but no sound would be heard (volume controls did not work anymore either). When I turned the car off I would hear static coming from the front driver speaker without the key being in the ignition at all. It stopped after some time.
The next day I checked the fuses and noticed the amp fuse (20A) was blown. when i replaced it and turned the key to give contact sound would work again, but every time i started the car the fuse would blow again. it does not blow when the key is turned to ACC or the other position.
-factory bose system
Not sure if this has anything to do with it but the driver power window button does not work since the same day the sound stopped working.
Any one have any idea by chance?
