itguyredskins
- Nov 4, 2010
Hello,
I was looking for some guidance with a Random Cylinder Misfire.
Specs:
2004 2500HD 6.0L
202000 Miles
Symptoms (other then code):
What appears to be an exhaust leak from the left side of the engine in a constant air pop noise. It gets quieter as the truck runs and you can't hear it at around 3k rpm.
Things I have done:
Changed plugs and wires
Checked vacuum tubes (which there only seemed to be two)
I don't have an EGR valve
My PCV value seemed fine.
Fuel injector cleaner has been added on multiple occasions.
Unless I did it wrong the propane test did not show anything (tested around throttle body, vacuum hoses and intake manifold.)
Other info:
Truck idles fine under any condition
There was never a code for a specific cylinder and coils are fine
EVAP is not giving any codes
No rough idle or stalling
No hesitation while accelerating
I don't feel any misfires
The engine light will flash and then eventually stay on.
I'm not sure how to check the exhaust manifold or if I missed any vacuum hoses. I'm worried I won't pass emissions. I have not done a compression test, I don't think I need to, plus it's a pain.
Any help is much appreciated.
David
Specs:
2004 2500HD 6.0L
202000 Miles
Things I have done:
Other info:
David
