2003 GMC sonoma 4.3 4x4 automatic
Having some issues with my truck. Throughout the winter, if the temperature dropped below -10celcius i could guarantee it wouldnt start when i went out.It kind of sounded like it wasnt getting fuel, just cranking. After leaving it a few days it would start right up.
A couple of times in the summer it would try and turn over and start but quickly there after die out (usually only run for a second or two). After leaving it for 15-20 mins it would start and run fine.
A few days ago it died again, volt meter in cluster is reading extremely low (9.5v or something)(did this everytime) and cranking but acting like its not getting fuel. Put a fresh battery in it, volts reading good but still wont run. Truck has brand new starter, alternator, battery. Distributor cap is newer and tried a different ignition coil but still nothing.
Hoping someone has had the same problem and could give me some answers. I do have a parts truck so if you have had the same or similar issue and found a solution let me know and ill try swapping a part from one on my parts truck.
New to the forum and hoping to find some answers!
