shaynehardy
My 1992 gmc jimmy s15 4.3L TBI stumbles while driving. almost like its not getting enough fuel to the motor. you can hear the fuel pump prime and when its running. help
Well so far i have replaced the entire distributor including cap and rotor as it was bent, i have done fuel filter as well i put a fuel injector cleaner through the gas tank but before replacing the fuel filter and then i have done a new air filter cleaner gasket, new pcv valve, new pcv valve hose, new serpentine belt, i have also done a radiator flush and changed the fluid back to the oem orange longlife fluid. i also swicthed up to 87 gasoline instead of the 85. im also getting poor gas milliage as in 180 km to a 3/4 of a tank of gas. i have a k&n air filter thats 100 % clean i have also got my tires balenced and allignned. and my truck is still stumbling or starving for fuel when i just randomly stomp on the gas, also if anyone has any suggestions of better fuel economy that be appreciated.
Also things replace two years ago:
Distributor cap and rotor, spark plugs, spark plug wire set, fuel filter, power steering pump, alternator, water pump, radiator, oil change every 4000 km, heater core, pulled the dash and sealed the heater box inside the vehicle up again.
