transmission fluid change
961kyle
looking at changing fluid in my transmission, never done it on my suburban before but i have done it on a blazer i used to have, wondering if anyone knows roughly how much fluid i will need to do this, also if adding the lucas transmission oil to it would be beneficial, my father in law i bought it from pulled his 12000 pound camper with it so im sure the tranny has seen its better days, any advice is welcome
another question, the oil cooler in front of the radiator, is that tranny fluid cooler or engine oil? might be a stupid question but i dont know
1994 GMC Suburban SLE
Hey Kyle, see your doing a great job on taking care of your Suburban.
1994 GMC TRUCKS SUBURBAN 5.7L 8-cyl Engine Code [K]
Automatic Transmission,4L80-E......AF6 AMSOIL Synthetic Transmission Fluid Torque-Drive® Synthetic Automatic Transmission Fluid
Product Code: ATD1G-EA
CAPACITIES:
Automatic Transmission, 4L60-E Initial Fill..........4.7 liters
Automatic Transmission, Total Fill 4 speed 4L60-E..........10.6 liters
The cooler in front of your radiator??? Your going to have to trace the lines to see where it's goes. The transmission lines run on the passenger side and the Oil cooler lines run on the drivers side. That cooler was a add on, and it could be ether or. All depends on what the installer wanted the cooler to be, transmission or engine oil. :eek: Oh and don't forget the transmission oil filter too. :rolleyes:
A New "Recommended" Maintenance Item...
In the last few years you were probably asked, or told, by you dealer or quick lube place that you need an engine or transmission flush, because the engine oil or transmission fluid is very dirty. They will tell you that it is recommended that you have it done because your engine or transmission will last longer if it is flushed clean. In that they are correct, a clean engine and transmission will last longer. But is flushing the best way to get a dirty engine clean?
What Is An Engine Or Transmission Flush?
Flushing is the high pressure forcing of fluid back against the normal flow of the fluid. In other words if the normal flow is left to right, the flush would force the fluid right to left. This is accomplished by connecting a machine that will force special solvents back through the engine and transmission. The idea is that by forcing cleaning solvents backwards through the system, it will get all the junk and garbage that has formed over time and "flush" it out of the system. In theory this may be sound, but in actual practice, it's dangerous.
The Dangers Of Flushing...
Flush machines do what they say; they force high pressure cleaning solvents back through the engine and transmission and clean out some of the accumulated junk that has formed. Now engines have small passages and galleries through which oil or automatic transmission fluid flow and there are one-way valves that keep the fluids from backtracking. By using an aggressive cleaning procedure like flushing, large chunks of accumulated sludge are broken off and forced backwards through these galleries and valves and, more often than not, lodge tightly and block them. This cuts off the normal flow of the fluid and causes lack of lubrication in an engine and abnormal or no shifting in a transmission. The results are expensive repairs, or more often, engine or transmission replacement.
Who Recommends Flushing As Maintenance?
The shops that want to sell you the engine or transmission flush charge anywhere from $49.95 to $99.95, not including a new engine or transmission. Those are extra. And they state quite emphatically that it is recommended that it be done. But who actually recommends that it be done? If you check with GM, Ford, Chrysler, Nissan, Honda and several other new car manufacturers and not one recommended an engine or transmission flush as routine maintenance. In fact, they specifically don't recommend it at all!! The new car dealerships that do sell them use the implication that since they are the dealer that it must be the factory that recommends it. And if they do say the factory recommends it, they are flat out lying to you.
The only ones who do recommend flushing as a maintenance procedure are the companies that sell the flush machines and the shops that buy them. The flush machine manufacturers state quite clearly in their operating manuals not to use their machines on "high-mileage vehicles". That simple statement proves that flushing is not a safe procedure. It also absolves them of any responsibility of any damage that may occur due to the use of their equipment. This leaves the shop wholly responsible for anything that happens and the cost of correcting the damage that occurs.
The fact is, if you do frequent engine oil and filter changes and service the transmission every 45,000 miles there is no need for a flush. I have change my engine oil and filter every 3,000 miles and I don't use fancy oils and filters, and after over 45,000 miles, the transmission oil comes out almost as clean as it goes in. I have regular transmission services and my transmission still shifts like new, well better then new even with well over 365,000 miles on it.
If you have neglected regular oil changes and you want to do some interior engine cleaning, get the oil and filter changed and replace one quart of motor oil for one quart of Marvel Mystery Oil. The Marvel Mystery Oil has a very low viscosity content that will clean the engine without damaging it. Do this every 600 miles before you service the engine oil and filter and you will clean the inside of the engine slowly and gently.
If you do get a flush, I recommend you do it when you can afford to replace the engine or transmission.
keep up the good work kyle.
how do i find out if i have a 4L60-E transmission? or is that the standard tranny? also is the 4.7 liters what it will take after dropping the pan and changing the filter?
Yes the 4.7 liter is just dropping the pan and replacing the transmission filter. Look at your pro codes in your glove box, M30 is the pro code for the 4L60E.
You have a 1994 Suburban with a 5.7 liter, there was no 4L80E option for your SUV. The 1995 Suburban 5.7 and 6.0 liter have the 4L80E transmission option. :D
As for the Lucas transmission oil treatment, i try not to use any of that kind of additives that raises the viscosity to the transmission fluid. The higher the viscosity of the transmission fluid creates the higher retention fluid and is known to cause the shift solenoid to stick and or the TCC to stick. Here is what to do to check on your transmission's condition.
Put a line pressure gauge ($55 shipped on Ebay, or visit a local trans shop) on the pressure test port and go for a drive to verify proper line pressure. Base pressure at idle in P,N,OD should be around 70psi and around 140psi in R. Max line pressure should be at least 190psi at WOT in 1st or 2nd, 225psi is optimum. If base pressure is low, trans or pump is worn out. If max pressure is low, check EPC solenoid. If reverse is slow to engage, and line pressure does not come up to at least 130psi in reverse, replace the boost valve with a Transgo 0.500" boost valve (easy fix in pan). Adding a high-viscosity additive such as Lucas Transmission additive or other seal restorer product is good for Soft shifting, gradual performance degradation from Poor line pressure rise due to leaking boost valve, clogged EPC filter screen, failing EPC solenoid, or worst case: leaky seals throughout.
