Where can i find paint colors (2) in my 1990 GMC Sierra?
sniperlif3
Well as i stated, ive got a 1990 GMC Sierra and its 2 toned a dark blue and a silver/blue colors stock and im looking for touch up paint for it... Where would i be able to find the exact color code or name?
The easiest way to find the paint code is to look for the sticker or plate that has the paint code listed and is located in the glove box, and plate on the body on the fire wall. Even if you get a correct paint code, it will only be an approximate match to your car's exact color. In most cases, it will be an exact match or close match, but some colors, especially metallic and pearl colors, will have many variations for the same paint code. There are so many other places for the paint color code to be located for GM cars, so if you do not see the code on those places mentioned above, we recommend that you check your Owner's manual for your vehicle for the location of paint color code. The Owner's manual does not tell you what the paint color code is, but it tells you where it's located on your vehicle. If you do not have the Owner's manual or the paint color code is illegible, contact the dealer with the VIN number on your vehicle, and they should be able to provide you with the information.
GMC Brand paint color code has many ways of labeling their paint color codes, but what's important is the "WA number", which is usually a 3-4 digit code indicated as WA-U9095, L8798,(our information shows the code as WA9095). If your vehicle is a two-tone, the number you need will follow a "U" (for upper body) or a "L" (for lower body). If your vehicle is a single color, the code should be easy to spot.
Paint Color Code Looks Like:
Usually a three or four digits and start with a WA, such as WA9095 or without WA such as 9095. If the vehicle is two-tone there will be an “L” (for lower) or a “U” (for upper) before the numbers. Example: WA U-9095 or WA L-8798. GM Pro code usually lists two codes on every vehicle. There is usually a two digit code, such as 47U - 90L.
Color Paint Code for the 1990 GM trucks
White 12/WA5111
Light Slate Metallic 17/WA7468
Black 19/WA5118
Bright Blue Metallic 24/WA9222
Yellow Clear coat 35/WA9414
Light Mesa Brown 37/WA9219
Dark Mesa Brown Metallic 40/WA9202
Dark Blue Metallic 47/WA9095
Dark Red 48/WA9096
Saddle Metallic 67/WA8799
Bright Red 72/WA7475
Dark Maple Metallic Clear coat 78/WA8800
Wheat land Yellow 87/WA9418
Tangier Orange 88/WA9417
Gray Metallic 90/WA8798
The Break Down:
The first part of the paint code is a reference to an RPO code Like 47U or 47L. The U stands for upper color and L stands for Lower color. This is if you have a two tone paint job. The WA9095 is the reference number to the color. It will be show Like U9095 or L8798.
rpo codes as follows:
47U : PRIMARY COLOR, EXTERIOR, DK BLUE MET (91)
90L : SECONDARY COLOR, EXTERIOR, GRAY MET (91)
Good luck friend.
