do not play the radio/cd or anything --- key OFF to change out the seat ... get your measuring tape and write down the spaces of the bolt positions of both seats as they fit to the cab floor ... that way you know if the sizes are the same and will fit -- most likely yes ... key off __ unplug wires under the seat and then remove the bolts ... those bolts are tough so use a 1/2 drive socket and get good leverage (using the same bolt in the same hole will be easier going back together.. THE other thing will be to consider that the plugs match ... if the plugs don't match then you must find the same seat or go to an upholstery shop and get an estimate of repairs ..
