I'll apologize for the long post first but I'm a bit baffled as to what has happened.
I was driving to work and suddenly my AC didn't feel cool. I looked and the AC button was not lit up so I hit it, it flashed and went back off. I hit it again and it did the same thing again.
It's an '09 that I've had for 3.5 years and I wrote it off to needing a recharge and took a mental note to look into it later.
About 5 miles later my truck started "dinging" at me and the dash said I needed to service stabilitrak. WTF?
Then ""service traction control" with the light showing on the dash. Then "overheating. idle engine" The truck barely had power to pull away from the traffic light I had stopped at but then seemed to pull away normally. Next was the warning that the AC was disabled due to overheating. I was trying to get far enough to get pulled over safely and another warning "overheating. decreased power". Finally got pulled over and sure enough, coolant was leaking out. I let it cool for over an hour while I met with a client that was nice enough to pick me up and help me out. Bought some coolant to put back in it hoping I could limp it home to check it out. Didn't get very far. Towed it home and let it cool for a while.
The only thing I could see is the bottom radiator hose was wet around the neck. I bought a new one and removed the old. Neck and radiator looked good. No rust or cracks that I could find BUT I also couldn't find any cracks or holes in the hose. The only thing I wonder is if the clamp had lost it's grip since it broke easily when I removed it. Everything else looked good as far as I could see.
I put the new hose on and no leaks. No overheating. Truck was quitting after starting the first couple starts though.
BUT traction control, light, service traction control warning, and service stabilitrak warning, and engine light were still showing. I also noticed my engine hours had reset to zero and the outside temperature was showing as 55 degrees (I WISH!). I tried my AC and it was working again EXCEPT it was cool on the right side of the truck and blowing hot on the left side of the truck.
I shut it down, finished putting my air filter box back together and unhooked the battery again to see if it would clear warnings.
Went out after dinner and hooked the battery up, started fine, let the truck run for a bit, took it for a test drive. No leaks, no overheating, no warnings or lights, no engine light.
BUT the engine hours are still reset, now showing only the mileage from my test drive, my AC is still blowing cold on the right side of the truck and hot on the left side, and it still says it's 55 degrees outside.
I have a theory/suspect cause but I'm hoping an owner or mechanic has experienced this and can tell me precisely what's going on.
Thank you in advance for any help getting my truck straight. It's been a great truck to this point with no major issues and I've kept it maintained religiously. Hoping to keep it.
2009 Sierra 4x4 1500 5.3 flex
