Have a 2000 Jimmy Diamond Edition that won't start. It cranks like it wants to but doesn"t. Sprayed starter fuild but still doesn"t stay running. Someone says it could be the fuel pump. How easy is it to replace the fuel pump?
Thanks for your help. But how do you test the fuel pressure, and where is the shredder vavle?
I think i"m going to replace the fuel pump. Put a new fuel filter on but nothing happen. Fuel pump sounded weak. So wish me luck.![]()
Sometimes the pump will come on if you hit it and then goes back out again. Could this mean the pump is going bad or the fuel regulator need to be replaced. Far as the ground wire where is it connected and where does it run to? Confused.
