allenjkmeier
- Jul 16, 2019
My 2013 Yukon XL Denali recently started slipping out of gear when coming to a complete stop at a red light, stop sign, etc. Once I let off the brake, it kicks back into gear but can take up to 3 seconds to do so. If I hit the gas prior to it kicking back into gear, it kicks in really hard.
I had the transmission fluid changed but that didn't seem to help. The vehicle has approximately 132k miles. In addition, the vehicle sputters a bit when the RPMs get too low--almost as if the vehicle doesn't downshift quickly enough. Depressing the gas pedal a bit more tends to alleviate the sputtering but, prior to having the issue with it dropping out of gear when stopping, this didn't happen.
A friend of mine hooked it up to a code reader (he's a mechanic), and there are no error codes whatsoever. Has anyone else had this issue? If so, was there a fix for it? Thank you in advance for any advice you could provide!
