ONe issue I still have is when i connected my ignition relay connected it wants to keep cranking like I have the key turned. So What I determine is there is a short in the switch or the a wire coming out of the switch to the relay. I took the lower steering column plastic off and see where a remote starter was wired in. There were wires to something that were all cut still spliced in, but covered by tape. Which wire is the hot wire when the ignition is engaged, because instead of replacing the whole switch i might just put a push start on it. Any help would be great!!!
