sofasurfer
- Apr 30, 2010
'95 Sierra 1/2 ton 4x4.
I have the new ball joints. Bolt on for the upper. Press on for the lower. I have the cotter pins out...yippee...worst part is over
Do I just unbolt the control arm from the ball joints and it will drop far enough? Or do I need to remove the caliper and tie rod? What do I do with the upper rivits...grind them off? Obviously, but I felt that I need to verify first.
Any suggestions or help will be appreciated.
